remove 2 sided tape
http://www-.luthiersforum.com/forum/viewtopic.php?f=10128&t=47336
Author:  mikemcnerney [ Mon Feb 22, 2016 6:39 pm ]
Post subject:  remove 2 sided tape
Today I glued my bridge on a tenor uke
I used 2 clamps with a caul both inside & out.
I used some 2 sided tape on the inside caul in order to keep in place white I positioned the clamps.
Too clever!
I cannot remove the inside caul which is approx. 3/4" x 3/4" x 3"
I made a L-shaped block & tried to knock it with a hammer, didn't work
I'm wondering about using some kind of solvent though it will not be easy applying it where I need it.
please help!
Author:  SteveSmith [ Mon Feb 22, 2016 8:25 pm ]
Post subject:  Re: remove 2 sided tape
Naptha will release it.
Author:  Jim Watts [ Mon Feb 22, 2016 10:21 pm ]
+1 on the Naptha
Author:  mikemcnerney [ Tue Feb 23, 2016 4:05 pm ]
Walked in to the shop with the naptha method on my mind & the caul had just 'popped' off
thanks folks
Author:  wbergman [ Thu Feb 25, 2016 7:25 pm ]
You probably should still remove any adhesive residue.
You are lucky it came off. I did a similar thing 20 years ago under the bridge extension. The block is still there. At least it has no acoustic effect.
